I would also advice to check the belt tension, in particular the small belts on the motors.
You can tighten them by unscrewing the motors, push them down and tighten them again.
You can also try to align the belts, because it seems like they are skipping steps.
Align them in a way that they are paralel to the axis.
Have you checked if all the pulleys are screwed on tight?
dojan 0
Are you sure it's not skipping steps when you rise the speed, because of either lack of lubricant/oil on the rods; lack of belt tension; or bad alignment of the rods?
I have had strange stopping/starting behavior, in a few cases I believe because of to small baudrate on Linux, and in a few cases it fixed itself with a re-slicing.
