Hi tinkergnome,
I was thinking about implementing something like this.
If I read the thread that you point to, do I understand it correct, that you have already implemented the code for this in your firmware branch? That would be cool!
Hi tinkergnome,
...do I understand it correct, that you have already implemented the code for this in your firmware branch?
mmmmmh, it seems so...
I've only made dry runs, but Guglielmo (@gpb01) was (apparently) successful with it in real life...
I think the tunell sensor is surprisingly expensive, but i probably could take a fancy to the tiny cheap optical sensor...
Connect the three wires to the Ultiboard (EXT I/O aka J23) like here and you're done:
Mmmhhhh - personally i think it's cheap enough to give it a try...
... I've only made dry runs, but Guglielmo (@gpb01) was (apparently) successful with it in real life ...
:D... believe me, it works like a charm
You have just to adjust the timeout to avoid "fake positive alert" (default 8 sec. is too short, go to 20/25 sec.) .
Yes is expensive but ... the time to make the board, to mount, etc. etc. ... not worth it, better buy it
Guglielmo
P.S.: the only annoying thing is that you need to remember to reset the sensor before each print.
Edited by GuestYes is expensive but ... the time to make the board, to mount, etc. etc. ... not worth it, better buy it
The photocell sensor comes complete on a board for less than 2 EUR including shipping
For example: http://www.ebay.de/itm/Slot-Type-Optocoupler-Module-3-3V-5V-LM393-Comparator-Slot-Type-for-Arduino-DE-/251557847295
Edited by GuestThe photocell sensor comes complete on a board for less than 2 EUR including shipping
Sorry, but you're talking about two different things ...
... with your optocoupler you just detect that the filament is finish/broken.
What the "filament monitor" do is much more complex ... with a "rotary encoder" he detect the movement of the filament (... counting steps per time) and can alert you also if something goes wrong and the filament can't move (e.g. nozzle clogging, filament grinding, etc. ...) !!!
Guglielmo
tinkergnome 927
Hi Reiner,
as far as i can see it goes in the same direction like discussed here lately.
It monitors a specified arduino pin and enqueues a "M600" if the input is pulled down to LOW (by any sensor). That would be not a major change - i think.
But there is no activity on the UM2 Marlin repository since July... personally i would not expect such things in the near future...
