Ultimaker Dual Extrusion Set
Posted · Ultimaker Dual Extrusion Set
Hi @Ksheho,
The kit is only for the Ultimaker Original.
Do you already have one?
The assembly itself is pretty good, levelling the nozzles requires some fiddling and we have labeled the entire upgrade kit as experimental because overall it is trickier to use than single extrusion. So your expectation should be different than single extrusion.
is a video I found which I think should give you a good impression. Most prints will probably require some clean up.
