'Print one at a time mode disabled. Object too tall.'
Posted
(edited)
· 'Print one at a time mode disabled. Object too tall.'
The object is too tall for "one-at-a-time" cause if you place multiple of these on the bed, and the printer moves to the next one the already build can get knocked over by the x/y/ axis.
So you can print multiples, but only all at the same time. To print one-at-a-time the objects need to be smaller than the 'gantry height' which is the distance from the tip of the nozzle to the lowest of x/y axis (= 48 mm)
If a object is to big to print it will turn grey in cura.
In general if you want to see how cura behaves have a look at the layer view, this will explain the difference between al-at-once & one-at-a-time the best... just try both by loading a few small objects in cura.
ultiarjan 1,223
Edited by GuestLink to post
