Nylon settings (Picture)
castellina
Posted · Nylon settings (Picture)
Hi all, I printed this overhang test in gizmo dorks nylon, didn't turn out great. Any suggestions? Thanks
Current settings:
flow: 113%
Temp: 242c
Build plate temp: 64c
Infill: 20%
Print speed: 40 mm/s
Travel Speed: 150 mm/s
Cooling fan: off
Supports: off
