Replacement Ultimaker 2 control board
mls
Posted · Replacement Ultimaker 2 control board
Does anyone have any experience buying a new main board from China / Aliexpress?
A new board in europe cost around €350! The price from china with customs duty comes to around €150. A lot cheaper!
Hopefully someone can share their experience!
Regards,
Max
    Hi neotko,
    Thanks for the info. Should have searched it myself though!
    After reading your comments and those of others there were a few things I looked out for!
    http://www.aliexpress.com/item-img/3D-printer-accessories-Ultimaker-v2-1-1-control-board-Ultimaker-2-generations-board-finished-board-free/32474543921.html#
    I think the above link shows a pretty decent replica with power switch soldered on and the plastic (what part?) the right way around! Do you notice anything else wrong with that board other than the quality of certain parts probably being inferior?
    Regards and thanks again!
    Max
    I have one china board but I have not turn it on yet. I suppose as long you change the cable +\- or strip out the plastic of the molex on the board (I did that) it should 'work' but I would not leave that on at night just in case :)
    Thanks for the heads up! I'll probably end up getting an official one. The thing is i'm not sure if mine is broken or not! My issue is in another part of the forum:
    https://ultimaker.com/en/community/view/18073-another-ultimaker-2-heated-bed-issue
    Maybe you can give an opinion on the issue!
    Max
        • 30 replies
