Hi tinkergnome !
I am not talking about the ultimaker 2 marlin version but original version.
I have implanted in this original version the UltiLCD in, hum... I try it we will say.
I would make work the ENABLE_ULTILCD2 or ULTIBOARD_V2_CONTROLLER.
but I get this all error in compiling
I am using of course the ultimaker display
tinkergnome 929
That's a bit confusing...
You are talking about the firmware for an Ultimaker2, right?
...at least the "UltiLCD2..." files are used for the display of the Ultimaker 2
- this would presume a
#define ENABLE_ULTILCD2
The "ultralcd...." files are not needed - at least not for a stock UM2 - the same applies to "ULTIBOARD_V2_CONTROLLER" - are you using a different display?
AFAIK you would never need both?
