ultimaker original plus z stage switch adjuster and belt tensione clip
Posted · ultimaker original plus z stage switch adjuster and belt tensione clip
I printed this one for my UMO. I'm pretty happy with it:
http://www.thingiverse.com/thing:126716
I don't remember if I had to drill any holes or not.
If you have a clothespin - remove the spring and use that as your tensioner - that's what is used inside the blocks on the UM2.
