The solution for me was to increase the plugin value "Retraction amount" to approx.128 (for a filament diameter of 2.85mm). This compensates the 20mm retract when you resume the print.
That worked beautifully!
I understand now that the plugin assumes length, but the printer needs mm3. So you got the 128mm3 by calculating volume: 1/4 * pi * d2 * h.
Or 0.25 * 3.14 * 2.85 * 2.85 * 20 = 127.52mm3.
Some of my 2.85mm filament measures 2.80mm. I am curious if I should change the formula for 2.80mm or let the printer deal with the 2.80mm volume calculations. I have added a new material called "PLA 2.80" which has a 2.80mm diameter definition.
Edited by Guestleft out the last few words.
tinkergnome 917
Providing that you use the (standard) gcode flavor "UltiGcode", the Ultimaker2 uses volumetric values for the E-axis....and so does the Pause at z plugin (i think...).
You have to calculate the retraction amount for the plugin in cubic millimeter.
If i remember right, the change material wizard retracts the filament 20mm at the end of the procedure.
