is the a safety issue in the firmware that provides filament feeding under a point of temperature?
*sigh*
https://github.com/Ultimaker/Ultimaker2Marlin/blob/master/Marlin/Configuration.h#L266
#define EXTRUDE_MINTEMP 170
M302: Allow cold extrudes
You're talking about an Ultimaker2, right? M907 changes the motor current, but AFAIK there is no linearly dependency between torque and current.
What are you trying to prove....and why...? (just curious)
good morning
thanks for the answer ... M302 solved the problem (Y)
first of all, I would like to compare the force of the extruder with other people, and proove that my nema looses steps more often the older it gets, now I have 500h on it, and I feel the problem gets bigger,.. I know nema's are made for a lot more than 500h :)but something is hapening there,...
then I want to know how effective it is to turn the current up, do a diagram force on current, and proove that it does not take a big advantage see what the heat does on it,.. ect.
next step is a design with a gearbox for the extruder, it drives me nuts to go 25mm/s...
tinkergnome 929
*sigh*
