It's recommended not to take off the bed, because if you take of the bed you usually have to level it again. But sometimes your object won't come off and you'll need to use a hammer to get your print off, which goes easier outside of the machine.
hammer to get your print off ?what situation do you need a hammer ?
Ian
Sometimes, an object with a larger footprint ( like the owl: http://www.thingiverse.com/thing:18218) is easier to "knock off" with a hammer. With a tap against the (back)side and off it goes. But that induces shock into the bed and the arms which carry the bed.
Yes, technically one would not need a hammer - other weighted things would also work - and "hammer it off" sounds maybe a bit too harsh, as I don't smash the hammer into the object as you would when hammering a nail into wood =)
But some objects really stick well. I use yellow TESA 4840 tape instead of the scotch one. Got the idea from Gregor Luetolf and his Blog: http://www.3drucken.ch/2012/07/auf-der-suche-nach-dem-abdeckband.html
owen 19
You'd usually only move the bed off if you've got a heated build platform or something which is easily removable.
You wouldn't usually remove the standard bed as it is unlikely to be level when you replaced it.
