tinkergnome 918
Hm, this is hard to pinpoint.
To exclude an overheated stepper driver as the reason: you could try to reduce the motor current for the z-axis a bit (approx. 10% lower) - you can adjust it via "Motion settings" on the printer.
But i also see those lines from time to time if i use cheap filament (with unequally diameter)
Nicolinux 288
Hm, this is hard to pinpoint. I don't think it is a slicing problem but rather hardware. I think your best bet would be to find an objects that prints quickly and then print a few to see where the error happens. Also try to move the object on the heated be - don't always print in the center.
I am sure you checked this, but your filament is not tangled or obstructed in any way?
