Orientation of parts in Cura
Thadote
Posted · Orientation of parts in Cura
Hi
I have a wheel where the axle and front face of the wheel is NOT perpendicular. This means that when slicing the wheel "standing" on the axle, then the layers that makes up the wheel, is not symmetrical, Though the wheel is.
I care little for the axle, but want symmetrical print layers in the actual wheel, so is there a way i Cura to define a surface to be parallel to the printbed, and up?
The picture is what I don't want.
The .stl ...Link to file
    You can try the lay flat function. Or rotate it by hand by holding the shift key will allow you to rotate 1° at a time
    Is that the only option? there is no way do define a surface to be parallel to the printbed? such as in CatalystEX?
    The lay flat option tries to do this. It's a rather difficult problem, so it doesn't guarantee a perfect result.
