I'm using an old (6 years ?) Samsung Q1, with less than a gig of memory, wirelessly connected to a NAS that holds the gcode files generated on the workstation . Currently I run pronterface supplied with cura on both linux and xp with it.
Things that help are making sure the models are cleaned with meshlab; for more complicated models, minimizing the client once the print starts solves any other slowdown problems. You might get some sputtering if you bring up the UI again to adjust temp or anything else, but usually not a problem. Here's hoping that a future version of cura will have buttons a little bigger for my fingers to use with the touch screen. Having the touchscreen there really makes bed levelling and such easier.
Daid 298
The main issue you have with pronterface is that it loads all the GCode in memory, that's most likely your culprit. As other then that the GCode sender of Pronterface is as good as you can have it. (Only SD card will prevent blobbing)
