I plan on taking it back apart and making sure the wires are routed properly and free from damage. Does anyone have a picture of the wires coming down and to the fans, temp sensor and heater block? I just want to see if I can get a good idea of the proper slack and placement.
Thanks,Q
Labern 772
I have not had any interference with mine and have done a bit of work in that area. you may want to check for damage to the wires or loose plug connections.
