Hi Sander,
Cheers for the quick reply.
I understand the G-code thing and the way the model is sliced to build up the layers.
I want to check the supports in the printed file to make adjustments for the overhang angle to sort out problems.
Some pics:
The model imported as stl. With my luck my first project barely fits the platform and is a pain to position :(
This I see after loading the G-code
The layer bar at 265:
BTW: Are there any workshops/courses on working these machines and it's software in NL?
Just got the printer last saturday and would love to speed up the learning curve. Using it professionally, time is not on my side
SandervG 1,521
Hi @Erik-RS,
If you convert a digital 3D model, like an STL, into a g-code the file is being converted into a list with commands. That is basically what a g-code is.
A g-code is a text file which you can open in note pad for example or other similar tools.
When you reload a g-code in Cura a lot of data it previously used to create a visual representation is lost, so it can't show it the same image it showed the STL.
In the top right corner, you have the option to alter the view-mode from regular to overhang/transparant etc. One other option is layers.
It will illustrate the toolpath the head will cross while building up your model.
This is the only representation it can give you based on a g-code.
It loads every layer, so if it only shows part of the model you may need to wait a few sections before it finished loading the entire file. It can take a little bit longer than with a regular STL.
Let me know if this was helpful!
