Temp Sensor Error on Ultimaker 2 Extended+
lexJena
Posted · Temp Sensor Error on Ultimaker 2 Extended+
When does the error occur? When you start a print as it's heating up?
To remove those screws, lift the bed up and use the screw driver/allen key on the top side, and hold the nuts in place on the bottom side (as in your picture)
    • 3 weeks later...
    Thanks, but i think there is a problem with the firmware. Sometimes before I start the print, I go directly to tune the nozzle temperature and the temperature standing on 0 degrees. After I change the temperature there is no problem.
