White PLA Profile for Ultimaker
jay
Posted · White PLA Profile for Ultimaker
Im a beginner and so im trying to get a good start.
im using my ultimaker for the first time with netfabb.
can somebody help me with the right settings for white PLA so i can start with the best result possible and then start with the mod of it.
i think i have problems with the feed rate or temperature.
thanks
    thanks
    Are you referring to the white PLA from
    http://ultimachine.com/content/pla-3mm-white-5lb
    or from another source?
    The Ultimachine white PLA is a bit tricky to print, especially for beginners (IMO), it seems a bit temperamental, and I have experienced problems on longer prints (>3h).
    It is best to find YOUR printing temperature window first:
    https://groups.google.com/d/msg/ultimak ... Gm13BeZy8J
    https://picasaweb.google.com/lh/photo/C ... aNWFtjfw8o
    Let me know if that helps
    I use the Ultimaker white... I found printing temps from Netfabb need to be adjusted. On standard quality I do 220-225 degrees Celsius to get the material going. Lower temps result in extruder jams...
    thank you that helped a bit.
    im using the white PLA from the ultimaker shop on the site stabds more then 254°C
    what extruder settings are used with this. is there a place where several material defs are collectes to test them out?
    and thank you for your help
