gt2 upgrades
Posted (edited) · gt2 upgrades
Thanks Netko. Sorry I always get confused with the jungle of parts but sorted it.
will order from robotdigg
4x  606mm closed-loop gt2 belt
10x GT2 Pulley 20 Teeth 8mm Bore
2x  202mm 2GT-6 endless belt
2x  UM 20 tooth 2GT pulley 5mm
As the thread said.
But atm my printer dont do perfect circles etc so it may be wrong when I need
new x - y blocks.  only have pla what do u recomend?
And if you mean umo/umo+ belt upgrade (something you haven't clear) then it's 6mm wide, the length it's in the posted link (tooth = length)
    Posted · gt2 upgrades
    PLA works nice for the side blocks. Read all the posts from that first link. They explain all of it, that's how I learned to do the mod, and works quite nicely.
    Btw that bad circles might mean that you need a belt tensioner. Check the belts, they don't need to be tight, but just not loose. The guy that designed the side blocks has also a small tensioner addon for mxl belts that worked nice for me until I changed all to gt2.
    hm weird after a few prints today I managed to get some better circles. Dunno what happened to the machine.
    Started to experiment in sketchup with rings to fit A 10mm drill axle. First tried 10mm didnt work. Then 11 abit vobbly.  10.5 too small . And finally I thought 10.75 yes its A perfect fit.
    Also first time attempt for me to make something bolt on. And it sits tight. :)
    anyway this is my default tension
    pushes them untill it says stop. Do I need tighten ?
    very small difference compare to left.
    anyway I felt enthusiastic to upgrades , You know any high quality replacement shafts also? and bearings
    The best shafts you could get are from Misumi, I bough enough for my 3 machines, they move like silk and they are perfectly straight. Ofc, unless you have a banana shaft, isn't necessary.
    https://ultimaker.com/en/community/5103-ultimaker-black-edition?page=18#reply-115379
    There's a point where too much tension also give problems. I think on ultimaker wiki there was an old article about how should the belts 'sound' to check the correct tension.
    nice but tons of informations getting headache. Can u link the items you bought?
    It can't be linked. You need to search (on the link post you have the part name). Also misumi only sells to companies.
    This are the ones I got:
    https://ultimaker.com/en/community/17068-making-your-own-ultimaker-what-not-to-buy-on-china-stores-personal-experience#reply-125649
    okey then how did u get them ?
    I have a company, made an account, order, payed, installed it :D
    what shall I do lol I have no Company.
    weird saying no to money by freezing out 99% of the people :p
    Sorry, Misumi works that way. A good other option should be IGUS, afaik they sell to everyone and their product should more than just ok.
    Oh lol, I did bough some to IGUS... Well I have a shaft overstock, hopefully someday I'll make a fourth umo...
    This are the part numbers for Igus linear shafts that I got.
    SWMH-08 2,00 15,34 CF53-Welle, 8mm, h7, gehärtet,
    L=337 mm
    L=348 mm
    SWMH-06 2,00
    15,34 steel shaft, 8mm h7 hard- L=267 mm
    Their prices are around 5€ for each one, so it's almost a 40% cheaper than misumi. I have them in a box stored, the only ones I tested are the 6mm hotend x/y thin shafts, they work quite nice and they where perfectly straight, the other shafts I don't know since I didn't even open the box.
    hehe thank you for alternatives but cant downgrade my expectations now :p
    Oh lol, I did bgh some to IGUS... Well I have a shaft overstock, hopefully someday I'll make a fourth umo...
    L=337 mm
    L=348 mm
    SWMH-06 2,00
    Do u know what causing a cube to get slightly wider at higher layers?
    a 10x10x10 mm cube
    measured 3 spots, bottom middle top
    x 10.02  10.05  10.16
    y 10.00  10.10   10.18
    L=337 mm
    L=348 mm
    SWMH-06 2,00
    okey !
    I made a small conversion for the wooden blocks to allow gt2 belts.
    The mxl ones didnt move anywhere so gt2 will definitely be held in place.
    You might want to add 'teeth' to that printed part.
        • 21 replies
