All parts are new, bought from a licensed Reseller so i think it is not a cheap China product but maybe . i'will made Pictures after work so you can see exactly what my Problem is.
Filament stuck in hot end Isolator coupler umo
Then maybe you have an space because the peek/barrel ain't well inserted. Also, check that the nozzle must be tight (don't overdoit because it can break) while hot but the manual fails to explain that
neotko 1,418
Couplers compress overtime and dies, changing the size leaving a gap for the filament. You probably have a) a dead coupler or b) a china coupler with the wrong size.
Also propably you have black goo on the lower part of the barrel/peek. If so, you need to take out the coupler and do atomic pulls of the goo that it's between the coupler/peek and get a new ptfe coupler.
Make photos it's easier.
Example of black goo dead coupler https://ultimaker.com/en/community/18531-multiple-problems-see-picture#reply-128039
Edited by GuestLink to post
