What I´ve printed?
HMarcus
Posted (edited) · What I´ve printed?
Hi everyone,
In the following picture you can see my last print.
What I have printed or in what case this print is used?
Have fun while guessing if you don´t know what it is :-) .
    Reminds me of some designs I've seen for flexible/soft robotics. Something by Festo perhaps?
    Posted · What I´ve printed?
    No Christmas tree :D.
    Here another picture, where you can see the function of the joints.
    The print is a little bit defect because a child wanted to test the maximum capacity :O.
    I have glued it but the deformation is not that regular as it should be.
    Thats exactly what it is @IRobertI.
    Next printed "thing" :)
    It´s a modell in scale 1:10. The normal Size is approximately 4 m long.
    For what this thing is used?
    Paper making?
    If I see the right answer I will let you know. ;)
