Difference between layers
x3nomorph
Posted · Difference between layers
Hello all, can someone please explain me the difference between the two layers on the pictures?
The layer before looks messed up, the lines of the path and everything.
Cura settings:
0.2 LH
0.7 Shell thick.
0.8 B/T thick
20% fill
50 speed
does this affect on the print or is it just cura's display bug?
Thank you.
    Posted (edited) · Difference between layers
    I saw somewhere to look at Xray view in Cura also very interesting to see Red colored areas for problems. I do not think messed green can affect print job. Do you using 0.35 mm nozzle because of shell thickness = (I use actually) Nozzle size (0.4) x 2 = 0.8
    Thanks for the fast answer.
    With the Xray view I see some red spots, but they arent on thoose layers with the mentioned problem.
    I use a standard 0.4 nozzle, but somehow I saw often a better result in cura with the 0.7 shell thickness than 0.8.
    Btw using older cura version 14.12.1
    Picture 1 : Layer with retraction
    Picture 2 : Layer without retraction
    That means that its nothing bad, its just for information? :)
    sorry for multi post, the forum gave me a "server error" and i tried it again, but it seems posted every time....
    So than its just for "information" and doesnt mean anything bad? :)
    It's not bad ;)
