  • 3 weeks later...
Posted · hotbed activate in netfabb ?
Does nobody know how to activate the hotbed in netfabb for ultimaker ?
I really need it for ABS printing.
Thank you.
Fritz
Hi Fritz
Add to you Gcode the following
M190 S110 ; Turn HBP on and set to 110 degrees
M140 S0 ; Turn HBP off
Took me forever to find that when I built mine and it doesn't work in RepG 34 only RepG 26 and Printrun etc.
Good luck
    Thank you.
    Fritz
    Hi Fritz
    Good luck
    Thank you very much.
    I will try it
    Fritz
    Thank you.
    Fritz
    Hi Fritz
    Good luck
    Did you put this into the Gcode header in netfabb ?
    Fritz
    Fritz
    Yes
    M190 in Header
    Put it in place of your preference
    I put mine before heating the nozzle so that the HBP temp has time to stabilize and the nozzle is heated for a shorter amount of time before starting the print.
