Well I obviously do not know for sure if it has a lot of friction, but the theory I came up with is because of the fact I torch out the nozzle when it gets clogged.
This torching gives the nozzle a dull look, because of oxides formed in the process. This oxide layer has a slightly rough feeling to the touch and I can imagine that materials have more friction to this surface compared to the bare brass metal.
This is just a theory, and I can't really come up with something to test this properly.
As you can see in the pics below. The knurled bolt is clean, and bearing (instead of the POM wheel) pushes the filament against the knurled bolt very well.
When I try to pull the filament out while rotating the extruder gear, I need quite a lot of force to let the filament slip.
SandervG 1,499
Why do you think the nozzle has a lot of friction?
Could you also upload some pictures of your feeder?
Have you checked if none of the internal parts of the feeder show any signs of wear?
Could you also upload a close up picture of your knurled wheel?
- is it clean?
