Hi SandervG
Basically, it reboots hisself. So black screen lights go out and then it reboots hisself back on.
Hi SandervG
This problem is still occuring, I really hope someone has a solution for me.
Hi Horsiris,
Thank you for your post.
I have double checked with our technical department. I think it might be your electronics that short circuited but let me double check first.
Your last post completely missed my radar, our apologies for the inconvenience.
Will report back asap
- Have you also been in touch with your reseller?
Good thing I checked, I got an unanimous conclusion that it most likely is a short circuit in your heater cartridge. I would suggest to get in touch with your reseller to have it replaced.
Thank you for your time and patience!
SandervG 1,522
Hi Jeroen,
What do you mean by crashes? Does it reboot itself, or you can not continue in the wizard?
- If you prefer to communicate in Dutch, we also have a Dutch section on our forums where all of our Dutch friends hang out. In this section English is the desired language.
