This is typical underextrusion. Pretty severe - Somewhere around 30% to 50% of the extrusion desigred (half to a 1/3).
There are many possible causes. The likely problem is either your teflon part or your nozzle. But first the most common problem is that people print too cold or too fast. Check the table below to see if you are printing too cold or too fast (fast has to do with layer height also!).
If you have the Olsson block this might be a good time to install it. Read the directions carefully - it's very very easy to destroy the temp sensor - but the guy who wrote these directions changed 100 blocks and only damaged one temp sensor so read his technique. Change the teflon part while you are at it. Often there is a thin coating of gunk inside the nozzle - especially if you printed with ABS a few prints ago. You can either put on the olsson block or you can remove do a cold pull, then remove the nozzle and soak it in acetone overnight (again be very very careful not to damage the temp sensor). Here's the directions:
There are about 15 other possibilities so tell us more information (e.g. I changed the nozzle - that's not it, I change the teflon part 2 days ago - that's not it, I am printing same speed (but thicker layers) that used to work).
Here are my recommended top speeds for .2mm layers (twice as fast for .1mm layers):
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
The printer can do double these speeds but with huge difficulty and usually with a loss in part quality due to underextrusion. Different colors print best at quite different temperatures and due to imperfect temp sensors, some printers print 10C cool so use these values as an initial starting guideline and if you are still underextruding try raising the temp. But don't go over 240C with PLA.
I'm excited because I've personally produced this showcase event, so if you are curious what else I'm up to nowadays, come check it out and say hi in the chat! It would mean a lot!
gr5 1,841
http://support.3dverkstan.se/article/62-installing-the-olsson-block-kit
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
