The rating of the default steppers is 1.2Amp. Not sure where you got the 2 Amps from Owen? So you need at least 1.2 Amps, but it's better to have some slack there, especially because at the max rating they usually need a lot of cooling.
If you are in europe, you can get new drivers from UM, but if you are in the US that might be a bit expensive and then I personally would go for the black pololus.
owen 19
Hi
You could check out your current rating of your stepper motors and you might find they are 2 Amps, so 2 Amps + is going to be best.
