Is the MarlinSimulator being maintained? How do I use for a rotary button and an SD card?
jayeye
Posted · Is the MarlinSimulator being maintained? How do I use for a rotary button and an SD card?
Working off https://github.com/Ultimaker/Ultimaker2Marlin
at SHA 12b4cb9fad232411dd2b1cafe821547ee5f1e272.
I can build and run MarlinSimulator (W7Pro, Code::Works 16.01 with MinGW, SDL 1.2.15, all freshly installed), and get to here:
Clicking anywhere or pressing random keys does nothing (OK, ESC exits!).
Clicking on the red square turns it to green, and then the firmware displays an error message:
Am I doing something wrong? There are no instructions on how to run the beast (I'm grateful it even exists!). Has anyone other than Daid successfully run it?
Thanks,
/ji
    It's intended to be used with the arrow keys and the enter key (ok, and ESC :)).
    And it needs a bit of patience - depending on the menu it needs sometimes more than one key stroke on the arrow keys to move the selection.
    Does it not function?
    oh, ...and put the mouse aside...
    • 4 weeks later...
    Brilliant. Everything works fine now.
    I'm taking the opportunity of having to disassemble my UM2 to install the UM2+ upgrade to add second display, which I can read while standing up!
        • 31 replies
