File export
rtrecha
I use a mac. How do I export a file from Autodesk to Cura for printing on a Printrbot.
Autodesk can export these file types:
IGES (.igs .iges)
SAT (.sat)
SMT (.smt)
STEP ( .stp .step)
Archive Files (.f3d)
Curt uses .stl files ???
    Posted · File export
    IGES (.igs .iges)
    SAT (.sat)
    SMT (.smt)
    STEP ( .stp .step)
    CURA uses .stl files ???
    • 7 months later...
    Autodesk has a whole bunch of different products that could be used for 3D printing - from TinkerCAD, 123 Design, Fusion360, Maya, Inventor, AutoCAD etc. pp.
    Which Autodesk Software are you using?
    Here are 4 Autodesk products i am using:
    a) Fusion 360: use the Make > 3D Print from the Toolbar, uncheck "Send to 3D Print Utility" to save to STL - or try if you can send to your slicer as "Custom" utility.
    b) 123 Design: Export to 3D > STL or: select the part and click "Export Selection"
    c) TinkerCAD: File > Download for 3D Printing
    d) MeshMixer: File > Export
        • 24 replies
