In general the motors are no issue, they can handle a lot of heat. Exception is the feeder motor, here the motor can transfer the heat to the filament in the feeder causing melting/grinding. This is solved in the UM2+ due to the indirect connection from motor to filament, I placed the feeder+motor outside of the box.
In my experience with a full enclosed UM2 (with E3Dv6 + ABS), the cooling of the hot end is a bigger issue when the heat inside the box gets to much (+/- >50c ?). I solved it by simply drilling a few holes in my top cover...
ultiarjan 1,221
Here's what I use;
https://www.youmagine.com/designs/um2-minimalist-front-panel
https://www.youmagine.com/designs/ultimaker2-top-cover-clips
https://www.youmagine.com/designs/ultimaker2-rail-system-u2rs
Edited by GuestLink to post
