The 100% fill was a mistake. I forgot to change it from a previous print. I'm going to change it to 20%.
I'm going to try printing cooler and slower and I'll let you know how it turns out.
Will the UM2+ upgrade work on the Go?
I won't be getting my upgrade for about 2 weeks so I don't know for sure but I strongly suspect it will work fine. I know for sure it can handle the higher wattage heater as I already have a 40W heater on my um2go (and a heated bed). There's nothing else about the upgrade that leads me to think it won't work - certainly the fan thing should be fine. The feeder might require the um2go motor to turn a different direction - but I know you need to load different firmware for the um2go to become a plus anyway. So, yeah, I strongly suspect it will work fine - ask me in a few weeks.
Plus I don't know for sure if the new fan shroud will help your print on the right side. I just know more fan is better.
gr5 1,839
100% fill is not necessary and wastes lots of time and plastic. If you need something strong enough that a car can drive over it - try 3 shells (1.2mm) instead of 2 (.8mm).
The issue is that because the nozzle is on the left side of the print head, you get more fan on the left side of the model. I'm not sure what the solution is - I guess print cooler. Try printing at 195C on the printer and slow it down to 30mm/sec.
Of course getting the UM2+ upgrade *might* help as I think it gives you more fan power.
Or just print something larger - or print 2 at once so one has more time to cool while printing the other.
