Looks like the z scar. What Cura version are you using?
What travel speed have you set?
Cura version um.....15.04.4
Print Speed(mm/s) 35
Also print is tuned to go 90% of that
Edited by GuestLooks like the z scar. What Cura version are you using?
Edited by GuestI found reducing the speed percentage makes it worse.
Cura 1.99 allows you to select different positions for z scar.
Also if you set the travel speed to 250mm/s helps also not having the acceleration to low.
Labern 772
