Posted
(edited)
· Severe under extrusion and filament flow issues?
I don't know this slicer so I don't know what the extrusion multiplier of .8 does exactly but it sounds like it would underextrude by 20%. Are you sure that's correct?
Too cold, too fast. Your bottom layer is .35mm thick, with .4mm nozzle and 60mm/sec that is 8.4 mm^3/sec. much too fast for 200C. Try 240C if you are going to print that fast or slow it down to maybe 10mm/sec for the bottom layer, then 20mm/sec for the rest. The UMO can print that fast at 240C but you are still pushing it a bit. I recommend you print at half maximum speed as shown below. For the bottom layer of course it's almost twice as thick so print half these speeds...
Here are my recommended top speeds for .2mm layers (twice as fast for .1mm layers):
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
The printer can do double these speeds but with huge difficulty and usually with a loss in part quality due to underextrusion. Different colors print best at quite different temperatures and due to imperfect temp sensors, some printers print 10C cool so use these values as an initial starting guideline and if you are still underextruding try raising the temp. But don't go over 240C with PLA.
gr5 2,067
20mm/sec at 200C
30mm/sec at 210C
40mm/sec at 225C
50mm/sec at 240C
Edited by GuestLink to post
