Well the um2+ series have different clips that hold the glass because the old clips where causing too many fingers to bleed.
Now I guess the new ones aren't tight enough?!
I would put a thin sheet of rubber in there somehow to keep it from moving around. I've had the head hit parts with pretty incredible force before - the equivalent that if you did it with hour fist it would knock the printer a few inches across the table. Maybe 10 pounds for 1/10th second?
So yeah - I would increase the gripping power of those clips. Maybe get some glue stick under them onto the glass?
gr5 2,224
Wow! I've never seen that before!
