Thank you Labern for the information. Then I think the machine can handle the sensor and the heater error. What about the motor? If the motor is blocked, it will run until burned out, right? Since I hit this issue previously, I printed 3 models, but 1 fall down from the bed to the bottom. When the printing is finished, the machine try to make the bed touch the z-stop, but the bed is blocked by the model. Fortunately, I heard that the motor is blocked and turn off the machine.
Edited by GuestThere is protection for the heaters. If there is a problem with the temp sensor the it will stop the machine, alarm and cut the power to the heater.
The machines a pretty safe and I leave mine going all night all the time.
The main problem is if you enclose the printer unsafely, but if its in it natural state then i don't think you have anything to worry about
if you are still concerned there is a unit that you install above the printer that has a smoke alarm that cuts power to the printer if it detects smoke. Its not for sale any more but you maybe able to rig something up.
Labern 772
