Hello, Thank you for your help,
you mean the Version: 15.06.03 ?
I tried to send to print and I could not see the "print Bottom" :
I will try again....
Thank you
Alberto
Thank you
Alberto
No there is another Beta version that's not public yet. I don't know when it will be released though.
Thank you very much.
I will keep an eye, even if you know before me, please let me know.
I do appreciate your help and information.
Gracias
Alberto
Note that 15.06.03 (and the newer-but-still-old 15.10 beta) also has the wireprinting functionality, and though much has improved during the past months the wireprinting functionality hasn't. The wireprint settings need to be made visible in the preferences (settings, all the way at the bottom).
In short: if you want to try wireprinting, download 15.10. If you don't feel like using unfinished software, wait for a public release of 2.1
Thank you very much, I will try and wait for the newest Beta version,
Gracias
Alberto
New beta is now online.
Wireprinting is a bit buggy. though.
When you encounter underextrusion, try setting the flow on your printer to 638%
The tip for the high "WP Flow" is especially true if you don't have a UM2(+).
Also you may have to increase the "WP Nozzle Clearance" to something a bit higher since the UM2 nozzles are a bit pointier than the UMO nozzles.
Nicolinux 287
Hey Alberto,
with the latest stable Cura version (15.04.4) it is not possible to print the object as wireframe.
But with the latest beta version (wich is in internal testing phase right now), this is possible. So I guess it won't take long and you will be able to print the wireframe.
