Get time printing formula
A2D3D
Posted · Get time printing formula
Can you help me ?
I installed curaengine on linux server
How use PHP for STL file ?
Thanks
    php can execute other programs - you will have to launch the curaEngine from within php - wait for it to finish and then examine the output and locate the time. This is advanced programming and not easy for a beginner.
    Thank you
    How find php codes or document for this ?
    Or if one line of returned text isn't enough (it probably is) then use exec().
    Thank you
    Can you help me more ?
    Can you give me command line for STL file load and get data ?
    I check document of github and php.net but not found anything for use php command line for curaengine
    Sorry - you should be asking these kinds of things on a php forum not here. If you play with curaEngine and examine the output and then have questions about that - then maybe this forum is appropriate. I think you need someone who is more advanced with php than yourself.
