Thanks Daid !
Thats question 1 out the way....
Now final question....
Can the standard UM electronics run this stepper motor, at 5000rpm, at full step mode (so about 2000 steps per
second).
http://www.micromo.com/Micromo/Stepper2 ... 24_PCS.pdf
Thanks Daid !
second).
5000rpm is very VERY high for steppers, not sure if those motors are up to that. But I think the electronics could manage it.
Ok many thanks for your help Daid !
at that speed you could use it as a CNC lathe
Daid 303
Current mode. The pots on the drivers adjust the amount of current.
