Please critique my #3dBenchy
vince805
Posted (edited) · Please critique my #3dBenchy
I sliced this with simplify3d with the default Ultimaker 2(I have a um2+) settings. What do you think and what would you recommend for settings changes? Thanks!
    Posted · Please critique my #3dBenchy
    Looks very good. I wouldn't change a thing.
    btw what were the speed setting for travel moves? I found the default to be a bit slow.
    Owen
    Owen
    I will have to check when I get home. Thanks for the response. I will try speeding it up some, it would be great to get a little faster.
    Here are the speed settings:
    You can change all the ones that have a % to 100. What you lose by printing the outside faster you can gain by printing everything at a constant extrusion rate.
    I just started using Simplify3D myself and didn't notice these settings at first and subsequently was printing fairly slow. 65% of 40 = 26mm/s. I also upped the X/Y Axis Movement Speed (Travel Speed) to 200mm/s. This greatly improved stringing.
    If you rotate the part 45deg it will get rid of the zebra stripes.
    Sounds like a nifty trick, I'll have to test this out. Thanks!
    This is good stuff! Thank you for your input. I will make those changes and I'm excited for some speed increases!
