hi Robert,
sample part size that I drew on sketchup. not sure of the printer manufacturer its a marlin, rep rap, ultimaker clone, I use cura 15.04 and get the same results with both abs and pla set to their recommended temps.
hi Robert,
hi Robert,
sample part size that I drew on sketchup. not sure of the printer manufacturer its a marlin, rep rap, ultimaker clone, I use cura 15.04 and get the same results with both abs and pla set to their recommended temps. the model size should be 24 x 39 x 7.5 but comes out at 28 x 44 x 7.5.
I think it has ramps hardware, I bought the printer 2nd hand and have no information with it.
Edited by GuestSounds like the number of steps for the X and Y isn't calibrated well. What does the top layer of the print look like, is it fully closed up or is it more like a cross-hatch type thing?
I would try using Pronterface to move the head 10mm in X and then measure exactly how long it actually travels. Same for Y. And then try modifying the settings accordingly:
hi Robert,
success! when I 1st put the new settings in the machine they kept getting overwritten by cura when I sent the print to the machine, but following your lead and a lot of experimentation I managed to add some programing to the start of the g code and now my prints are true to scale and I have gained a lot more experience
thanks again
dave
IRobertI 516
10% sounds like a lot.
Which printer do you use? Which plastic? Temperature? Other settings? How big is the part you're printing? Does it always happen, or just with certain models?
