Posted · filament skipped out of the nozzle in two pieces.....i don't know how to fix it.
I tried to make a print and the filament wasn't coming out no matter how much I tweeked it. i don't know how to get the broken filament out or how to get it to print again. :( :O
    What do you mean by "skipped out of the nozzle in two pieces"? Pictures might help because I don't quite understand what you're trying to describe.
    I think there is a clog in the nozzle, some filament is still stuck inside the nozzle/bowden tube, due to breaking when trying to remove it all.
    Depending on your printer I'd say the best way is to heat up the printer to 260 degrees C or so, and either try pushing the filament out again, or take the hot end apart and the removing the clog(probably the melted plastic went up to far and cooled down in a higher part of the printer.
