Ultimaker 2 Extended rebooting while trying to start a print.
Posted
· Ultimaker 2 Extended rebooting while trying to start a print.
When it starts to print the current draw is higher on the power supply. It's probably the power supply. Well I have 2 theories:
1) You don't have the proper power supply or it's defective - it should be 221Watts. Maybe you have a um2go supply by accident?
2) The power cable is not on all the way and falls off when it moves. The connector is supposed to snap and lock the cable in (the outer sleeve slides) and sometimes the PCB under the machine is too close to the edge of the hole and you can't get the connector on without a huge effort.
Posted
When we moved the Extended printer for maintenance we accidentally connected it to a um2go power supply. The Extended seems to be printing as it should, thanks a lot for your help!
1
gr5 2,330
