Hi DidierKlein,
Curling,.. hmm.. I think I prefer bowling ;-)
Ok, i'll play around with different layer heights, maybe a 0.150 next. I wonder if different temperature / cooling options might influence this as well.
Thanks for pointing me in the right direction!
DidierKlein 729
Hi and welcome,
This looks to me like curling due to the overhang. There's no real solution for this at the moment, it's due to the retraction of the material basically. And indeed it doesn't surprise me that you don't have that issue with 0.2mm layers because this effect reduced with bigger layers.
You can check this topic which explains it more in details
