hey daid
thank's for your reply, I'll try the sewing machine oil...
i also took some sewing machine oil.
but what about dry graphite lubricant powder.
can this be an option too?
http://en.wikipedia.org/wiki/Dry_lubricant
Do not under ANY circumstaces use graphite dry lubricant. I already posted about that before.
Graphite is a very good electrical conductor, and using a dry lube means there is nothing keeping the graphite stuck to your rods. You also have several fans on the machine....do you see where this is going....conductive dust blown through your electronics board, your fan motors etc etc.
Do not use graphite on your UM !
good point.
Daid 301
WD40 attracts dirt, it might run smooth now, but it will grind to a hold soon. WD40 is not a lube! It's a water-displacing anti-corrosion tool.
Best is to use machine-oil (sewing machine oil), on the rods. Note that some machine that have been collecting dirt in the bushing will push out the dirt with the oil after applying oil. If you see black stuff on the rods during printing, clean the rods and apply new oil. Repeat until it stays clean. This could take quite a few prints.
