Cura shows differnt to print
darsh87
Posted (edited) · Cura shows differnt to print
Hello guys,
I am Stuck trying to figure out why my print is coming out slightly wrong. its a symmetrical shape however one corner comes out "squashed" Please see images i was wondering is it the software thats caused that or is there a problem somewhere with my printer maybe one of the belts? Many thanks Any help much appreciated
Layer: 0.1
Shell: 0.9
Print speed: 40
Nozzle size: 0.3  {only way i could get small detail to show}
Temperature: 205
Material White PLA
    • 2 months later...
    Posted · Cura shows differnt to print
    Can you check the file In layer view in cura? It may look fine on the normal view.
    Does it fit the build volume with no problem or is it really close to the edge?
    Hello thanks for replying i figured it out and the print edge is very close to its limits when the head comes around to do that corner the fan scraps the side of the wall.
    lucky its only a prototype so not much of an issue however i'm sure its not meant to touch the sides so any ideas what could be causing this to happen?
    Bend the fans in a bit. With power off push the head to extremes. The black plastic head should hit the black plastic side block before the fan hits the wall. Maybe take a photo or google photos of um2 head.
        • 28 replies
