Posted · Wiring for blue Stopper
Hi guys, just assembling my kit and noticed there were notes saying the labeling for the stoppers were labeled wrong. The post was made 10 months ago and I haven't found any info if it was ever corrected. Is mine labelled correctly? How would I check if I wanted to make sure? Sorry if this is an easy question :?
    same here... the lableing is incorrect but the first start configuration on cura does the trick (though i figure if you just switch them from the start it would work properly. I got mine last week.)
    Hey guys, just an update. Tested the wiring for the stopper finally and it has indeed been labelled CORRECTLY. :)
    Most likely you also have a kit with 2 slots in the back for the extruder? These are newer kits with a bunch of upgrades in the lasercuts.
    Yep. 2 slots!
