CURA 2.1 and Delta printers
bobd
Posted · CURA 2.1 and Delta printers
Hi, does anyone know if it's possible to configure CURA 2.1 for a delta printer, or if this type of printer will be added to the "add printer" section?.
    It is possible, but it takes quite a bit of work. You need to provide Cura with a circular disallowed area.
    A better solution (like the old cura had) is up to comunity / companies that build Delta printers. We won't build support for it, as we don't have delta printers.
