Is there a way that I can access Cura from another software/micro ?
Posted
· Is there a way that I can access Cura from another software/micro ?
Why would you want to write a stl folder using Cura? Cura uses stl as input (and is generally used to create g-code files as output).
If creating g-code without an graphical interface is what you want, you can use the curaEngine in command line. You can find information on how to do that on https://github.com/Ultimaker/CuraEngine/#running
nallath 1,123
