fbrc8-erin 263
Glad to help! We've got instructions up for replacing a lot of parts--there's instructions for just about all of the hot end parts, as well as the whole XY axis if you ever find yourself needing to replace the belts.
Edited by GuestGlad to help! We've got instructions up for replacing a lot of parts--there's instructions for just about all of the hot end parts, as well as the whole XY axis if you ever find yourself needing to replace the belts.
fbrc8-erin 263
Those are great instructions for replacing the board, Artiz. We also have instructions available on fbrc8.com: https://fbrc8.zendesk.com/hc/en-us/articles/206495413-How-to-Replace-the-Main-Electronics-Board-UM2-
You definitely always want to update the firmware on any new electronics board you receive; the standard firmware on the board is an older version of the Ultimaker 2 firmware, so if you have a 2+, or Extended, or Original+, it will be firmware for the wrong machine altogether at worst, and an outdated version of your machine's firmware at best.
In addition to the difference in the green terminal blocks on the board (as you showed with your two boards) the other thing people might see as different between an older board and a newer one is the presence of a black relay switch near the connector that controls the rear fan. The original version of the boards had the rear fan running 100% of the time. There was a switch at one point to make the rear fan only power on when the printhead is at 40 C or hotter.
Artiz 27
Your instructions are far more comprehensive so that should do it... thanks for posting up!
P.S. That last bit of info is also very important from fbrc8-erin regarding the fan... I thought there may still be something wrong because the fan kept switching off/didn't come on etc... so good to know!
Edited by GuestLink to post
