Ultimaker 2+ fan setup - needs improvement?
Posted · Ultimaker 2+ fan setup - needs improvement?
Hi all:
Has anyone noticed any uneven cooling with the Ultimaker 2+ stock fan setup?
Is the stock UM2+ fan vents (horizontal oriented with metal shroud) an improvement over the UM2?
Should I try and print a mod fan shroud even for the UM2+?
I'm not too concerned with overhangs; but I would like to have even surface on all side of printed objects. I generally print slow with very small layer heights.
Thanks for any observations!
    UM2+ fan shroud improvment has a huge impact on print quality. Difference between the same print via UM2 and 2+ is visible.
    You should maybe check your calibration before trying to change the shroud, plus I'm not sure it would be a siginificant improvment ! (:
